Honda Manual Transmission Fluid
The oil did shear and the acid level is increasing.
Try Specialty Formulations MTL-P which has higher tbn (approx. 13) to fight acids and is full synthtetic so it only shears back about 1.5 cSt over 30k.
Hi
IF U have access for Liqui Moly gear oil 75w80, go for it, its great.
I use it in my integra turbo, also all my friend with all with honda's and all with turbos, they find it great, smooth sifting and ease. Its a synthetic technology high performance gear oil (GL3+) SAE 75w80, and if u want more protection u can add also Liqui moly product called (Ceratec) its great and u can use it in the engine to it makes miracles. This product saved my friend engine. Do u imagine an 800hp engine working without oil circulation, because an oil pump failure and every thing in the engine remained as new! We couldn't believe our eyes after dismantled the engine apart. That's how good it is.
Also the engine oils that they have they are really good that u can feel the difference. We all use Liqui moly Products in our cars. Made in Germany
Regards
Ivan
