I need some advice. Went with Amsoil 0w-30. Good choice or bad?
1992 Toyota 3L V6, 83k miles... reasonably well maintained, but not great. I use this truck for snow plowing now, so low miles but heavy work.
Dino oil exclusively up until now. Had low oil pressure problem, so dropped the oil pan last month and found a sludge monster and an almost completely blocked oil pump screen. Cleaned her up and put in 5w-30 Valvoline for a very short interval or 3 weeks. Oil pressure looks good until engine is worked for a while, then it goes low at low idle only. Responds to RPMs good though - according to mechanical guage.
Decided to go synthetic, even with the high mileage/age, to reduce deposits and help clean the engine. If I find any leaks I'll fix them (none so far). I chose Amsoil 0w-30 due to detergent package. Used the Amsoil engine flush and dropped the pan once more just to see if it washed anything out - it was clean. I'm thinking of doing a 6 month OCI.
Did I choose wrong? Should I have gone w/ M1 or Redline 10w-30 or is the Amsoil 0w-30 a good choice for my application?
Thanks,
-john
Thanks,
-john
