A set of tires, inflated at the maximum allowed PSI on the sidewall (e.g. 44PSI), is less likely to blow out during high speed driving on a hot day, vs. a set of tires, inflated at a lower, vehicle manufacturer recommended pressure(e.g. 35 PSI). Same load condition is assumed.
