quote:
Originally posted by George Bynum:
I've trimmed the OP post.
Originally posted by CapriRacer:
For example a P215/60R15 has a maximum load of 1411 pounds and that occurs at 35 psi. Use a lower pressure and the load is reduced as well.
However, the sidewall of a P215/60R15 can say one of 3 pressures: 35 psi, 44 psi, or 51 psi. Regardless of which pressure is listed the maximum load is 1411 pounds and that occurs at 35 psi.
.....Web research shows they have 2 different tires of this size, one with a P, one without. The ratings differ.....how can the same "size" have different service descriptions?... [/QUOTE}
There are several ways:
1) Extra Load va Standard Load. This is where a tire uses more inflation pressure to carry more load. Typically an XL tire will use 41 psi.
2) Different standards organiztions - There are 3 major one - TRA (Tire and Rim Association = US) ETRTO = European Tire and Rim Technical Organization (Europe), and JATMA = Japanese Automotive Tire manufacturers Association.
While these organix=zations have slightly different syandards for load and infltion they are pretty close.
For example a P215/65RR16 (TRA) has a 95 Load Index (1510 pounds at 35 psi) and a 215/65R16 (ETRTO) has a Load Index of 98 (750 kg at 2.5 bar = 1653 pounds at 36 psi). If you poltted the 2 curves, you would see they are pretty close, but they are ever so slightly different.
hope this helps.
