Umm, as a tire goes faster, as does the heat; it will go up depending on how fast the tire is going. The speed rating also has to do with how well a tire can take heat at speed capacity. You most certainly can take a lower rated (and its just that, a lower rating) tire past its speed rating. Is it safe for the tire? No; when a tire is tested for a certain speed rating, I'm sure that they test it beyond its given speed because at speeds any higher, the tire's integrity begins to degrade hence the rating given.
