Normally the pattern is too bring the rear tires up front then cris cross the front tires to the back.
My brother in law likes to just switch the tires from front the back on both sides of the vehicle. Meaning he'll jack up one side then just swap the front tire to the back and the back to the front. He will do this on both sides of the vehicle. He says this way you don't have to use 2 jacks and he claims that if you do it the per recommended way, this will screw up your alignment. What do you guys think?? Thanks,,,,AR
Edit: If your confused to what I'm talking about, I can make a small video clip if you would like?
