Actually, mixing is ok if you go over the details of your mixing plan with your mechanic and parts counterman at the local auto parts store. You can discuss the interactions caused by mixing different additive packages and their effect on seals and lubrication. Also check to see what they have to say about TBN support and the different methods used by various oils that you may choose for your mix. Also be sure to return with your uoa to verify what's happening in your engine. The advise that the sales people at Kraegan, Advance Autoparts, Napa, Pep Boys and other parts store can be the difference between just guessing and getting it done right. You should only mix oils after considering the complete chemistry of each package. The original package can always be improved for your specific situation. And, be sure to go back to your salesman to verify future uoa's are on track. After looking at the numbers, they may be able to advise you on adjusting the mixture for your next oil change. With all this help you sould be able to come up with something much better than just using the oil straight out of the bottle.
