quote:
Lye will react violently with aluminum, but not with iron. Used carefully, it will remove the remains a siezed piston from a cast-iron cylinder bore without resorting to a machine shop.
A couple of years ago, my wife left a stainless steel pot on the stove and the food burned on so badly that I couldn't pry it off with a putty knife. On a lark, I poured in some lye based crystal drain opener we had and added a little water to it. A half hour later the stuff rinsed right out.
People use lye to strip chrome off of plastic. I don't know what it would do to the plating on a spark plug, or to the ceramic insulator.
