an idea that works well, as long as your drain total is smaller in size than your drain jug. Take a 5qt oil jug (this size works for me being the car hold 3.75qts) drill a 1/2inch hole in it's cap which will allow the Fram SureDrain tube to slide into(the orange plastic tube). When it's time to drain the oil, you just slide the jug under the car, remove the SureDrain cap and pull the drain tube out just enough to thead it on for draining. When done, just untread and slid the tube back into the jug and then take the jug to the oil dump site-wherever you get rid of your oil. It works great along with it also working well for a oil sample valve by removing the orange tube from the oil valve nipple and than just screwing it on enough so as to control the amount of oil being let out into your sample bottle, when you have enough you just unscrew it to stop the flow.
