I do A/c and Radiator work.
A customer brought in a 1972 Dodge powered Motorhome. It has a 440.
I replaced some A/C lines and charged the A/C system.
I did not touch anything else on the thing.
I was running it at 1500 rpm when the lifters got noisy and it began to rattle. I quickly looked at the stock oil pressure guage and it was all the way at the bottom of the guage. I then shut the thing off.
I checked the oil. It is ok. I then removed the oil filter (Fram PH43) and it was full of oil. This is the correct filter for this engine (Although personaly I would not use a Fram)
The filter mounts directly to the oil pump which is external on BB Mopars. I was able to squirt some oil into the passage that leads to the pump, thinkin it lost it's prime or ?
I put the filter back on and ran it for 15 seconds or so while I tapped on the Oil Pressure Reliefe valve passage with a small hammer.
Nuthin. Of course the customer is blaming me even though I was working on the A/C and never touched the engine.
Anybody got some easy tricks or ideas?
