Well, are you talking about a single action or a double? Or do you have one of those semi-automatic- cop-killer-bullet-shootin' revolvers that the media tells us about?
For a single action I'd say you are overcleaning the gun and exposing yourself to some nasty and expensive chemicals. Action blasters are as bad as brake cleaners from what I've read.
On my SA Rugers I remove the cylinder from the frame and scrub the window with an old toothbrush and some Shooters Choice. The cylinder gets the same treatment on the outside. The barrel and chambers get swabbed out and scrubbed.
I then wipe the gun down and let it dry. After a short while I apply some grease (Lubriplate 130-A, developed for the M1 Garand & M-14) to both ends of the cylinder and I make sure a little gets on the base pin. We are talking small quantities here!
Since I don't own a revolver smaller than .41 magnum I like the cushioning effect grease has on the cylinder frame interfaces.
If you don't overclean the trigger/action by blasting action cleaner into it they stay lubed and reliable for quite a while. I removed my grips/stocks from a custom Stainless Bisley .45 Colt before taking it to Alaska, thinking it should be cleaned and relubed. All the 130-A was right where I wanted it and it looked like new so I left it alone. I had been shooting this gun extensively with some real sledgehammer loads for practice for over a month. At least 400 rounds, 340 gr. LBT flatnose bullets at near 1200 fps. Ouch!
