quote:
Originally posted by turbochem:
Link to article
Interesting if somewhat incomplete.......i
This type of lube issue is actually very interesting, and not limited to guns. I am a mountain bike fanatic. I can't imagine anything more harsh on delicate mechanisms than biking for hours in rain and mud. Good mechanisms are not overly sensitive to dirt and are well sealed/shielded, but not in a way that traps dirt or moisture.
I have tried everything from light oils like tri-flow, to heavy oils, greases, greases thinned with oil, hot-dip wax lubes, etc. I finally stumbled across Amsoil metal protect sprays (regular and HD), which are easily some of Amsoil's best products. The "regular" goes on oily but dries to a light film. It's supposedly great for guns. The HD is really amazing. It dries into a heavy, lubricating wax-like coating that is completely water proof and dirt proof. It's fantastic.
I realized I had only been destroying my parts with oil and grease all these years. Oil and grease is designed to be used in SEALED, CLEAN mechanisms. NOT exposed to moisture, corrosive contaminants, dirt, etc. Grease and oil is sticky and will actually ATTRACT these contaminants and carry it into mechanisms. Grease or oil is not appropriate for exposure to harsh or dirty environments. It can be worse than nothing.
Since trying these new dry lubes (there are some other brands as well), I do not use ANY oil or grease on exposed mechanisms, cables or chains on my bikes, tools, under-hood, etc. unless it is behind a good seal. Metal Protect HD goes on, stays on, doesn't get all over you and your clothes, doesn't suck up dirt, is totally waterproof, seals mechanisms, and when covered with mud, can just be washed off with water to continue performing.
On the topic of guns, there is a lot to be said for a Kalishnikov that you can throw in the mud, swish it off, and fire it. If you are really out in the field, away from any pampered support network, and you need a weapon that always works, who needs a gold plated trophy that can't even endure a sandstorm?
Didn't the Isreali's even develop a Kalishnokov-like gun that was even better and more durable?
