Being issued a NSN means soldiers can buy it through the system. Otherwise it doesn't mean jack.
FP-10 failed my corrosion test (salt water bathe) whereas ATF and CLP passed w/ flying colors.
Are they claiming they meet 63460D? They could very well meet 63460 (the original) but not A, B, C, D, or the new upcoming E. Just because it says it meets all the 63460 tests does NOT by any way mean it meets/exceeds the 63460D spec (which is the latest as of right now).
AFAIK only BreakFree CLP meets the 63460D spec. The Rev E spec has not been released.
Does this make any sense?
quote:
So it is a better lube then Break Free and does not contain any petrollum distilats or PTFE. It is non-toxic and all natral.
Tests can be skewed to show only good results.
No petroleum distillates? All Natural? Sounds like a lot of baloney to me. All natural, to me, sounds like it will break down at a lower temperature much faster.
They claimed Militec-1 was non-toxic but the MSDS shows that when burned, it will release HCl gas.
I just know CLP isn't a very good cleaner, but it has worked very well if used properly. I.e. if you squirt a sh*tload into your M16 in the desert, expect it to jam. Don't blame the rifle or the lube, blame the person who squirted all that lube into the rifle. The media has blown this out of proportion.
[ August 25, 2004, 12:10 PM: Message edited by: metroplex ]
