I think I have finally found good cleaning stuff and good lubricants for my guns. It has been a long time since I used Kleen Bore but I have decided to go back to using their products. And also I am going to use Blue Wonder just in the barrel.
The Kleen Bore Formula 3 seems to clean a gun just fine. And it can be used as a lubricant as well. But the TW25B lubricant is great. It is a grease like stuff but it seems to work great on the slides and reduce carbon build up in the barrel. And I like the clean bore cleaning tools.
Blue Wonder is great stuff. It is expensive so I am going to use it only to clean gun barrels. I ordered it online and then discovered a gun shop locally where a guy sells it. But he is going out of business this month. So I am going to make the Blue Wonder last as long as possible just cleaning the barrel every few cleanings. The Formula 3 works good enough for just a standard cleaning.
I am very impressed with the TW25B. A guy did some testing and put his results on the internet. The testing he did was just to find out about protection abilities. The TW25B which is a pretty safe product was among the best. Other products ahead of it often contained stuff like clorinated lubricants that I want to stay away from. They can cause cancer. And one product that a lot of guys brag about was a farce.
I don't know if the TW25B would be okay for the soldiers in Iraq, however. It might attract dust in a dusty environment. But for me it is great. The Blue Wonder would work really good on those M-16s.
