Hello, I have a question that maybe someone here can help with.
My integra is used as a circle track race car. It's equipped with a 1.8 non vtec Ls engine. I am currently running 10-w30 mobil 1 synthetic oil and a purolator pure one filter.
This engine went through a complete rebuild about 250 laps ago on a 3/8ths and smaller tracks. We built it loose by honda specs in the bottom end, due to the high rev limit. I am turning a maximum of 8200 rpms.
Now when the engine is cold at idle (1100 rpms) it is producing 80 lbs of oil pressure. When getting ready to race it is about 180 degrees and producing about 35 pounds of oil pressure. But when pulling of the track at about 210 degrees the engine only makes about 15 pounds of oil pressure.
I was told that as long as it has over 10 pounds at idle that everything is fine. But going from 80 cold to 15 hot seems like a big gap.
I change the oil every 2 races and it looks pretty good when it comes out with just some light discoloration. Oil filters are pretty clean also after cutting them open.
Should I consider a different weight of oil or maybe another brand? Same goes for the filter is there something better?
Thanks in advance and I'm sorry for the novel.
Brian
Brian
