Well I have been watching this topic with interest.
Now what I can not understand is the massive gap between what you guy's in the States are running in Push Rod V8's and what us Australians have and are running.
Over the last 5 years I have tried to uncover this mystery of light weight vs. heavy and Mineral vs. Syn, and I'm still confused!
Lets get to the weight issue first:
Firstly our major racing category is the V8 Supercars. Simular to Nascars, but our tracks are not oval shaped.
Here is a typical engine:
5 Litre Small Block Ford V8 with SVO Motorsport Head and a 302 Ford Motorsport Siamese Bore Block with electronic fuel injection by Motec Engine Management limited to 7500rpm (category maximum) and 10:1 compression ratio and Control 98 octane unleaded fuel.
Estimated Power: Approx 640HP at 7500rpm and 460F/lbs torque at 5600rpm
Top Speed: 300 kph (186 mph) 0 to 100 in 3.4 seconds
http://www.tripleeight.com.au/
I have been lucky enough to speak with several chef engineers of various teams, and to my surprise the oils most teams are using are mineral 25w 50. I have a letter from one Team owner that said " We have tried several leading syn oils, but don't get the same valve train life as with minerals. All out testing has proven that with Push rod technology, low revs (7500) and two valves per cylinder, these engines benefit from mineral oils". One team known for outstanding reliability uses a 25w 60 mineral oil, and talk on track is that there camshafts and valve train come out like brand new.
I have also spoken to guy's at CROWER, CRANE, COMP CAMS, YELLA TERRA, to list a few. Funny thing is that all these guy's are listing Mineral 20w 50 based oils for these style of engines.
I have also spoke with head tech's from Castrol, Shell, Valvoline, and I have also been told the same. At least 20w 50's and stick with Mineral oils for V8 engines.
What I just can't get my head around is how you guy's are really hammering Syn oils and ultra light weight oils in Big, Old Tuff V8 style engines.
I know typically Australia is a bit hotter, 77 deg F on a low average, but it' not to justify the massive gap in oil recommendations.
I know with the current issue of damaging Flat Tappet cams, companies like Castrol are pushing hard there Edge 25w 50 Mineral oil just for that very reason. Claming it's purpose designed for V8 Street and racing use engines with radical cam profiles.
QUOTE CASTROL : Edge 25w 50. High Performance mineral based oil recommended for modified engines, including push-rod technology street machines and big bore competition engines.
Lets use a 86 350 Chev Camero. Check any Australian website and you will get told to run a 20w 50 or 25w 50, some will even say a 20w 60 and while your there ask any oil company here and they will stress to only use Mineral oils as Syn's don't tend to provide these engines with the best style of protection.
But ask that question here and you will get all sorts of things like 5w 30's and so on.
Now I don't know, so it's not a case of we right and your wrong, at all, but I am really trying hard to find how both ends of the scale can be right?
I would really love to know what actual oils the Nascars are using, because if major companies like Crower and Comp Cams are pushing quality, 20w 50 mineral based oils then sponsorship aside I'm guessing it would be pretty close to our V8 Supercars.
