I am looking for a recommendation for breaking in my 327 on the dyno. Also an oil to use after it is broken in.
331 (327 + .030)
Plasma Rings
Isky solid flat tappet 270/274, Lift .530/.535
Johnson Solid lifters with EDM .020
(direct oiling)
Ported RHS aluminum heads w/ 2.10/1.625 Ferrea valves.
9.8:1 compression.
Performer RPM Air Gap
Holley 750 Vac Sec (w/proform body and base)
I plan on using EOS for the initial break in.
What oil should I use for breakin and then what oil thereafter.
If I change the oil after 25 minutes, and then 1 hour later, can I switch to synthetic or a blend? is that too soon?
331 (327 + .030)
Plasma Rings
(direct oiling)
9.8:1 compression.
