I took my car to a roadcourse this past weekend and my engine died when I came into the pits after driving the car pretty hard. I was using valvoline 30wt race oil(I think that's what it said?). I've been breaking in the engine with a 30wt oil. The engine is a 327 c.i. chevy with solid lifters .57 intake and .58 exhaust lift. Springs are 210lbs. This engine only has about 700-800 miles on it, and its more of a street/strip engine. I'm not real sure of my bearing clearances. Its been about 5 years since this motor was built-which someone built for me. Any suggestions on oil to use? I don't want to go with a full synthetic. A friend in the UK recommended Castrol GTX 10/50 but I don't think you can get that weight here. I guess this is like a semi-synthetic or something? Should I go up to 20/50 or 10/40? Or go with like a straight 40wt Valvoline and see if it cures the problem?
Thanks!
-Mack
Thanks!
-Mack
