Hi, I am new here and am looking for a suggestion as to which oil to use in my '95 Mustang GT. The motor is a 343 cubic inch small block Ford, A4 block, Eagle crank and rods, Ross pistons, TFS high port heads, and a solid roller 700 lift cam. I am running two 76mm turbos as well. Right now the car is not fully tuned, in the fall we started tuning it and from the 'seat of the pants dyno' it feels as if its making about 850 hp to the wheels on pump gas, when I am at 14 psi. I plan on making about 1000-1100 hp to the wheels once we turn up the boost.
Usually I run Castrol GTX 20w50, and recently I threw in some Marvel Mystery oil. For filters, I use Motorcraft, I generally try to stay away from Fram. Yesterday I removed my intake to fix an oil leak, and noticed a some puddles of sludge sitting in the intake valley. I do not know if it was water that possibly got in there from the gaskets leaking and then froze up, or RTV, or the 20w50 oil and the cold weather. Keep in mind, the car was not run at all in the extreme cold (I'm in CT and the car is garaged w/o heat). I did run it prior to removing the intake, and it was about 45 degrees out.
So I am looking for a suggestion on what oil I should be running. The car is 99% street driven, and will be taken to the drag strip on occasion. It has a Canton 8 quart pan, and the car does leak some oil. I am working on trying to get all the oil leaks resolved, but I am looking for a good all around oil to run that isn't too expensive. I can't afford to spend $70 on an oil change, and I usually change the oil every couple months, probably getting no more than 750 miles on the oil. Another thing is that I am not sure if I am changing the oil too soon, I usually go by 'if it looks black, change it'. But some people say that doesn't mean anything. One cause of the frequent oil changes is the fact that fuel does get into the oil, especially with 160# injectors and since we are still tuning.
Any suggestions would be greatly appreciated!
