My brother recently got a '94 5.0 Mustang with only 40,000 miles. It has a 5 speed stick and 2.73 rear end. He says it came with Flowmasters, K&N filter, and a Hypertech chip. He had a Powerdyne supercharger (9 lb boost) installed which came with an upgraded fuel pump and chip. He really likes the performance with the supercharger and plans to go to 20# injectors. Also he wants to find a bolt in (no mods) larger mass air flow sensor. His has the 4 bolt flange (some connect differently) and is 60 mm. He is looking to move up to about 76 or 77 mm.
Anyone know of a bolt in air flow sensor that would fit? He wants to keep the stock airbox and ducting. Apparently the air flow sensor is the more restrictive part.
