Hi Guys,
I'm looking for a recommendation on an oil filter for my newly rebuilt motor. It's a Chevy BB 427 bored 0.070 over. It was built by a local race shop and dynoed at around 450hp. The builder (who has a really good reputation) wants me to run Mobil 1 15W-50 because of the way the clearances are set in engine. He also plugged the oil bypass in the block and installed high volume (not high pressure) oil pump. My oil pressure runs about 40psi at idle when warm and +60psi otherwise. He also recommend I run a Fram HP4 filter. I am looking for some other filter recommendations. It needs to be capable of high pressures. So far I have come up with Fram HP4, Wix 51060R, and Baldwin B279. I'm leaning towards the Wix just because of availability. The car sees only a 1000 miles a year and I change the oil once a year just before I stop driving it before winter.
Thanks.
Thanks.
