I have a big block Chevy that started life in 1987 as a crate motor. I'm installing a Crane 134691 cam and Howards DirectLube solid flat-tappets (to match my vintage Edelbrock TR2X tunnel ram). Some people pass out if you mention "flat-tappet" and "big block Chevy" in the same sentence, but I wonder if some of that is due to the decrease in ZDDP content of street oils. Still, I want to give my setup every advantage possible so I don't have to rebuild the whole engine while listening to people say "I told you so!"
Here's my plan of attack:
1. Outer valve springs only during break-in
2. Howards lifters
3. Moly assembly lube on the cam
4. A good oil with decent ZDDP content
5. A pint of GM EOS
Here are my questions:
1. What oil should I use? I'm partial to Valvoline (sentimental), so I was thinking maybe Valvoline Conventional Racing Oil or VR1. How much moly do I need? Do I need much detergent? 10W30 or straight 30?
2. What filter? It doesn't make sense to me to use a super-duper tiny-pore synthetic media filter because it would probably clog up right away and then all the oil would go through the bypass. Therefore it would also seem to make sense to use a big filter, maybe a Wix 51794?
2. Howards lifters
5. A pint of GM EOS
