IMOquote:
Originally posted by Hirev:
Anyone here ever wonder why most wear on street motors occurs when they are 1st started up? How else do you explain the higher wear that occurs on motors mostly driven on short trips?
Intersting thought but.....
The high rate of wear is from:
No oil flow and moving cold parts on startup
Not enough warm up time to stabilize temp's before hitting it.
Not just bearing inserts, but pistons, rings, cam and lifters........
