quote:
Originally posted by JohnBrowning:
1911 it has been discussed in length a number of times by a number of people. In most cases the terminology used is not the correct tribological terminology. Molakule,Terry,G-Man II,TooSlick have used the terminology "pressure - viscosity coefficient". You have only read a very little bit of what has been discussed here in the past. A lot has changed since this sites inception.
Many of us also go to Noria wich is much more technical. Noria has more tribologists and less regualar guys on the site. The idea or principal is all that is important the words used to describe the princapal have very little meaning on their own.
Most of us are not engineer, triboligists or tech.'s! I am a Tech and aproach oil from a stand point of observation of results and failures. I could care less in the end what the white paper's say. The engine will tell it's tale and can be easily observed both directly and indirectly with observation,tear down and UOA.
I am glad this site is not your site as the membership would be very small. If you have all the answere why even bother with this site or the vast majority of it's members?
Quote "I have used this term on here about 30 times here on the car and truck oil section. And it was kind of funny becasue it could not have been more clear that all the psuedo-experts preachers here in lubrication had never heard of it before. The density of lubricants goes up with pressure and in highly loaded bearings "
Even I have mentioned this very thing a number of times. I have mentioned this effect when talking about newtonian fluids! You might want to read the last 4 years worth of post's before you get so full of yourself.
