- SBC 406
- solid roller cam (street profile lobes, ~ 350lbs open pressure; gross lift 0.543/0.561 w/ 1.5 ratio)
- roller valvetrain (tips & fulcrums)
- crane "pro series" roller lifters (NO oil passage to the roller bearings like isky/crower has now)
- 6500rpm max
- california use (probably won't ever even be started below 40*F)
- infrequent starts (might not get driven for 3-6 weeks at a time)
- maybe 1000 miles a year, including 2-3 trips to the 1/4 mile a year (maybe 10 passes a year).
any thoughts on an oil? the engine is basically new (about 200 miles). currently running chevron 10w30 (has about 180 miles on it, and probably going to drain soon, as I like to go about 20 miles on the break in oil and another 200 on the first change, then go to normal intervals). My thoughts so far are...
- want something with good startup flow, so that the valvetrain and lifters do without the least amount of time possible
- something 'robust' to deal with the pressures in all the roller bearings in this engine
My first thought is GC. But until the new gold stuff is figured out, I'm leary. second thought is the M1 T&SUV oil. Or perhaps delo/1300 15w40 type stuff, but a little concerned with flow at startup of a 15w. schaeffers 20/50 racing synth blend is also interesting, but i don't need something that thick. Have read the comments about a light synth being better for the roller lifters, and the fact that my oil pressure is just fine even with the chevron 10w30.
