You fella's catch the new Azenis's?
Q1 2005
195/60/14
205/50/15
225/50/15
205/40/16
205/40/17
215/40/17
255/40/17
275/40/17
225/45/17
245/45/17
225/40/18
235/40/18
245/40/18
255/40/18
225/45/18
275/35/18
Q3 2005
185/60/14
195/50/15
235/40/17 (YAY)
215/45/17
255/35/18
265/35/18
315/30/18
They're now available in 18's (which should make many of you happy) and appear to be replacing the Azenis Sports. They also come in 235/40/17 W00t!!!!!!!!!!quote:
I went to sema today, and I'm holding the brocure in my hand for these tires. They're called the Azenis RT-615, and that is exactly what they look like. They uses light weight nylon sidewalls instead of steel (like the old azenis sport), and the tread compound is not supposed to get greasy when they heat like the sport does. The tech rep was telling me that they can be mounted with the large blocks on the inside of the rear rims to help produce oversteer for drifting or race tuning. They are aysemetrical and non directional, so you can rotate them front to back and side to side, and the sidewall is supposed to be as stiff (if not more) as the sport.
Q1 2005
195/60/14
205/50/15
225/50/15
205/40/16
205/40/17
215/40/17
255/40/17
275/40/17
225/45/17
245/45/17
225/40/18
235/40/18
245/40/18
255/40/18
225/45/18
275/35/18
Q3 2005
185/60/14
195/50/15
235/40/17 (YAY)
215/45/17
255/35/18
265/35/18
315/30/18
