I have a question, which oil would you guys recommend for an International DT 466 that I have in my pulling tractor. The engine is a single-turbo charged 6 cylinder diesel. The problem I have is from fuel dilution, we try to pump so much fuel into this engine that the oil gets diluted pretty bad from just a couple of pulls. Right now I end up changing the oil (3.5 gallons) after every weekend of pulling. I have been using Rotella 15-40 with some Lucas added in. I didnt want to use synthetics because the oil is only in the pan for two passes and the synthetics are quite pricey. What would you recommend??
thanks
thanks
