I would like your opinions/comments/suggestions on what oil to use on a nitrous assisted small block chevy. Do I stay away from multi-vis oils? straight weight oils? what is the best racing dino oil? what synthetic to use? when should I switch to synthetic oils? would using synthetic oils not let the rings seat if I use the Total Seal dry film lube? your thoughts are appreciated.
