Just abit curious what some of you guys might think about this...In many classes of racing roller tappets are not allowed or are otherwise not desirable...so with that leaving flat tappets left...typical cast iron cams with hardenable iron solid lifters with the typical valve springs ranging from say 110 to 140 lbs on the seat to 260 to say 400 lbs open type pressures.... on a normal domestic V8 with anywhere from a 1.5 to 1.75 Rocker ratio.
Do you guys think as far as oils go ... would a "tackier" oil that is more likely to stay on a spinning lobe/lifter would help with longevity more or would a "slipperier" oil be better for longevity ?...
What really would be the best additive package for longevity of componuts with no thought to CAFE standards at all ?
[ March 09, 2004, 12:38 AM: Message edited by: Calvin ]
