I participate in ice races. Typically the events are at 0 F to 35 F in temperature. Does anyone know of an inexpensive oil that will stand up and protect well against high revving abuse in cold weather. I was thinking the Rotella T or Delvac 1/SUV.
I've used Pennzoil Long-Life 15w-40 down to 0F in my 1500 Chevy (4.3L), and although cranking speed was slower, I had absolutely no "lack of oil" startup noise, which shows me, that although the oil was quite thick, it still was protecting the engine quite well on startup.quote:
Thomas, You should consder an ele heater and tarps to get it warm before you start. If it water cooled it's easy as pie. Just a thought.quote:
Only problem is there are times where the high is 0F and the lows in the evening are -10 to -20. I leave for the events quite early in the morning, so it's still around -15 or so when the car is started first.
I guess that's why I've been able to do full seasons (up to 30 events) of racing for the past 4 years on a high school/college student budget.quote:
Originally posted by davidc:
Thomas,
You've combined two things that are mutually exclusive.....
You can not use 'cheap' and 'racing' in the same sentence and be grammatically correct. There is nothing EVER cheap about any form of racing, no matter how inexpensive it initially may appear.
Keep the shiney side up!
Ciao
