I was reading the back of a Zerex G-05 bottle that I purchased for my 2006 Power-Stroke Diesel, and in the ingredients section it lists water as the 2nd ingredient (Water 7732-18-5)... does this mean it's already pre-dilluted?
Also, my 2005 Mazda 3 came with the "green stuff" in it from factory, and from what I understand G-05 is a good replacement for the "green stuff" so long as all the green gets flushed out. Am I correct in assuming the G-05 would be a step-up from the standard green? All my manual says is to use an Ethylene Glycol based coolant... it doesn't list any specs.
Thanks in advance!!
Thanks in advance!!
