quote:
Originally posted by boxcartommie22:
i use zerex g-05 40/60 distilled and water wetter and a bottle of bg's super cool..in my fords...and no precipatate
That makes me feel a little better.
I'm trying to figure out what to put into the cooling systems of our Hondas (CRX and Civic). And Zerex G-05 looks decent, and seems (at least by the stuff I've been able to locate on the web) to be compatible with the Hondas I own. So, unless I hear about something better, I was thinking of going with the G-05 (and distilled water).
However, I just got done buying a couple of bottles of "Water Wetter" (i.e. the WW is now a "sunk cost"), before I heard about the sludge problem (when you combine WW with some antifreezes). If the WW will help (even a little) without causing problems, I'll go ahead and use it (after all, it is already paid for), during the next coolant change. However, I really don't want to risk WW actually working against me (and causing the coolant to work worse, possibly producing sludge)...
Hmmm... I suppose I could get a partial answer by mixing up some G-05, some distilled water, and some WW, in a clear jug, and waiting to see what (if anything) happens with the mix. If anything settles out of that, I obviously don't want to do that "for real" (i.e. if it is bad when just mixing alone, don't let it near your car). Of course, for a real decent test, I would have to heat the mixture (in an old pan?), to see if there was any problem when the stuff got hotter (as it clearly would get hotter while doing its job as a coolant mix)...
