This may be off-topic, or worthy of creating a new thread, but I am thinking of this, bigtime.
1) Last winter a mechanic asked a few questions as to the specifics on the car, like he really knew just where to put the cardboard, how much, etc. This is what he proceeded to assure me of, too. The car was not exactly warm last winter (the winter before I had a 4-banger Hyundai)
2) In summer the needle (as opposed to idiot light) climbed up to 90 C frequently. I thought that was great; if anything my thermostat is either tried & tested, or a bit prone to not really fully open up until that temp. Today I drove 10 km (7 miles) and then got caught in construction gridlock. I don't think it ever went above about 70...nor did it ever last winter.
3) I have WaterWetter in the coolant. This alledgedly gets heat from where it IS to where it's SUPPOSED to be. In the summer, that is supposed to be from the engine to the great outdoors. In winter (and I have this from RedLine) it should help get the heat from the engine into the interior of the car, via the heater core. If the heat energy that would normally cause the needle to read 20 degrees higher, is actually going into the passenger compartment, great...but IS it?
* If we can assume that the thermostat has not changed its opening temp from a month ago, what are the main factors that is causing the engine to under-heat (it WAS above 32 F!) and what can I do about it?
I'd like to form a plan and at least one backup plan well before we hit 0 F
Thanks!
Rob
