quote:
Originally posted by Jelly:
This From Me:
Here's what I do for a first time flush in a vehicle with a few miles on the clock...
Buy many gallons of distilled water.
Buy two little jugs of Prestone Super Radiator Cleaner (NOT THE FLUSH!).
Basically, drain all the coolant from the radiator (using the tap on the bottom of the radiator) and fill it back up with distilled water. Run the engine until you fill the upper hose turn hot, and then drain the radiator again, and again fill up with distilled water. Continue to do this until the liquid flowing out of the radiator drain is clear.
BTW, make sure when your doing the routine that you have your heater on so you get the stuff out of the heater core as well.
Anyways, once the system is full of clean, distilled water, add the jugs of the cleaner and drive it around for several days (Instructions are on the cleaner bottle).
After the period of time, do the same routine again. Drain radiator and fill with clean, distilled water. Do this until the drain runs clear.
After this, fill radiator with new antifreeze/coolant (pre-mixed stuff is easier to use)...cycle system again, and keep filling and draining until you've put in enough antifreeze to equal the capacity of the system (whatever your manual says).
*This might sound complicated (or confusing), but it's very simple, and will leave you with a spotless coolant system.
This From TheTanSedan:
See thread on coolant flush posted by Oldwagon (page one or so); see first post by Jelly.
I hadn't tried this method since before the fall of Saigon . . . cause it takes forever, but boy does it work!
We have a Jeep Cherokee (XJ; 242 cid 6-cylinder) with its little bitty capacity system that -- even with [2] changes prior to the last (at about 58k) -- the outlined method got stuff out even up to the end of the final flush. Much more than the usual tee and garden hose OR the dealers powered machine. Think I used about 13-14 gallons of distilled water, or 3 to 4-gls per gallon of capacity, total; drove several hundred miles in about four days to allow system to cycle cold::hot quite a few times. (Normal business days).
Did this in winter. Heater core warmed noticeably faster than before (just like new).
