I'm going to try using a Canton 1 micron canister fuel filter as an oil bypass filter. I currently have their 8 micron mecca filter but I would like to filter the smaller particles out as well. I talked to the Canton guys and they said that the element would work on oil as well. They seemed very interested in the idea and wanted me to let them know how it worked out.
My concern is that the element does not have the capacity and will clog too quickly but they seemed to think it would be good for around 10K mi. I guess I'll find out if that is true or not. I was hoping that the 8 micron filter would take enough of the filtering load off the bypass that it just might work. The reason for this choice is that it would make for a clean setup with what I already have now, and I like their stuff. (Excellent quality and robust designs)
I'll be feeding it with -4 hose, with one end being terminated with a -4 to 1/4" NPT adapter. My question is will the 1/8" ID of the 1/4" fitting provide adequate restriction. Also what do you guys think about the idea???
Kevin
Kevin
