Thanks for the info, Gary- I have considered the setup you indicated, but I wish to minimize the breaking of the hardlines in this application. Also, since they're going under the truck and above the bellypan skidplate in close proximity to the transmission, I need to have as compact a system as possible.
I'll be using a Motorguard filter setup for bypass and ideally would like to run it as I stated in my last post. Do you see any problems with my not having a bypass valve in the FF filter, and if so can you suggest a filter that will attach to a 3/4-16 mount that has a bypass valve in the filter?
Hmmm- -come to think- I keep seeing folks use magnafine filters on transmissions in series with the pressure line to the cooler. I don't believe they have bypass in them. Perhaps worrying about bypass valve in the FF filter is much ado about nothing? What say you, sir?
