L Lost Pup Joined Feb 11, 2003 Messages 100 Location Home Jul 20, 2004 #1 The factory 3/36 warranty is about to expire on my F150 Supercrew and I have decided to install bypass filters for both oil and ATF and I have a question. Would a oil/ATF sample to test prior to the bypass install serve any purpose ?
D Dick in Falls Church Joined Jun 1, 2002 Messages 1,412 Location Falls Church VA Jul 20, 2004 #2 It will give you a baseline against which to compare. It will let you know if there are any immediate problems. If you are going to keep the same oil, it will show you if the bypass filter can clean up the existing oil.
S snoboy Joined Jul 1, 2004 Messages 301 Location Maple Valley wa. Jul 28, 2004 #3 LostPup, Do you know what type of bypass you'll install on your F-150?
