Alot of discussion has been generated on what is the best FF oil filter. Prices vary from $3 to $17 depending on the filter. Micron ratings vary also from 20 to 40, give or take. Also most premimum filters have a bypass valve to open in certain conditions, which in turn just flows the dirt back to the oil galley.
Now, one solution is to install a remote mounted bypass filter. Advantage is that most of them will increase the engine oil capacity by at least 1 quart of oil, has no bypass valve, samples only 10% of the oil at a time depending on orfice size, usually does not affect oil pressure. Some can remove condensation depending on the filter media used. You can also extend your oil drains with proper oil analysis. When you sell the vehicle you can remove the unit and install it on your new vehicle. With the price of oil this is an option to consider.
An interesting note on bypass filters. When Slick 50 came out and vehicles with a bypass filter on them had Slick 50 added, the bypass removed the PTFE as it was in very loose suspension, if at all. So at least if the owner got sucked in on that snake oil they didn't have the oil galley plugging and oil sump pick up problems.
Some people do not like bypass oil filters, just as some don't like Synthetic oil. And that is what makes the world great, we can all have an opinion, but remember to respect each others opinion even though you may disagree.
I DO NOT sell or work for anyone. I am retired and fish over 175 days a year, have 3 boats.
[ June 12, 2002, 11:25 PM: Message edited by: 59 Vetteman ]
