Schaeffers 15-40 JD 6081 345 hours
lllinois
Schaeffers Supreme blend #700 15-40.
code:
Eng.Hrs 676 1027
Oil Hrs 268 345
copper 4 5
iron 17 34
chrom 1 2
alum 3 5
lead 1 1
moly 141 338
phos 1816 1869
zinc 2047 2045
mag 15 15
calcium 5371 5797
silicon 3 6
visc 14.99 14.38
sulfur 5 6
oxi 4 5
nit 3 3
soot 0 1
fuel, H20 and anti-freeze all zero
Recommended to increase hours to 420.
[ September 22, 2005, 03:09 PM: Message edited by: 59 Vetteman ]
Hi,
importantly, no TBN or TAN?
All seems very good and subject to a confirming TBN/TAN this oil has lots of life left at 345hrs (the conversion factor we use is 1 hr=80kmh(50mph)so this is about 27kkms (17k miles)
What filters are fitted to this engine?
Doug
No tbn or tan with this uoa.
This tractor should land beteewn 600 and 1000 hour intervals.
The Schaeffer oil lab chemists look at so many tests that they can see the condition of the oil in things other than TBN. I don't know exactly how they do it, but they are confident of their work...and I haven't heard of any problems arising from their techique.
Ken
Hi,
Ken2 - IMHO like so many things, it is again another building block less for an accurate across Brands/Labs comparison
With diesel UOAs TAN or TBN should be mandatory - preferably both!
salesrep - yes, somewhere above 600hrs looks possible and the increasing topup will help achieve this. Top up to date is also not noted in the UOA
Doug
Doug
"yes, somewhere above 600hrs looks possible"
I think that this is the point here. Not the Schaeffer methodology. Schaeffer, as Ken2 eluded, is comfortable in recommending intervals based on thousands of uoa's with their own oils. It is our A** that is on the line and you can be sure that we will err to the conservative side.
