Chevron Delo 400 15W-40 CI-4 Plus.
23,700 mi / 800 hr - 41% Idle / 3625 gal fuel
Same Filter Entire Run (Fleetguard)
Water Temperature 10°F to 227°F
Oil Temperature 10°F to 205°F
Ambient Temperature -30°F to 75°F
CAT 3406E 475HP / 1650T (40 Qt Capacity + 16 Qt Add Oil). 554,100 Mi Total on Engine.
Iron 21
Aluminum 5*
Copper 2
Tin 3
Silicon 5
Sodium 2
Potassium 1
Moly 255
Boron 93
Magnesium 35
Calcium 3414
Phosphorus 1252
Zinc 1395
Fuel 0.5%
Soot 0.2%
Water
Other metals and additives 0
Additional Tests on order:
Visc, TAN, TBN, Oxid, Nitr...
"*Data flagged for observation only: Aluminum is still at a MINOR LEVEL." I believe they noted this because this is the highest reading this truck has ever had.
Gene
Iron 21
Aluminum 5*
Copper 2
Tin 3
Silicon 5
Sodium 2
Potassium 1
Moly 255
Boron 93
Magnesium 35
Calcium 3414
Phosphorus 1252
Zinc 1395
Fuel 0.5%
Soot 0.2%
Water
Gene
