Oil sample.07/3/04, 10/5/04, 18/9/04, 2/12/04
Oil Type
Fuchs Titan Universal HD, Fuchs Titan Universal HD, Mobil Delvac 1, Mobil Delvac 1
Total km. 103 094, 110 272, 125 620, 134 988
Oil km......3 714, 5 132, 5 351, 14 719
Filter......3 714, 5 132, 5 351, 14 719
Filters are Donaldson (1 full flow, 1 combination)
Analysis-Metals
Al...4, 5, 1, 5
Cu..1, 2, 2, 3
Cr..less than 1, less than 1, 1, 1
Fe..5, 7, 3, 20
Pb..4, 3, 8, 14
Sn..less than 1, less than 1, 1, less than 1
Contaminants
Si..2, 3, 3, 5
Na..less than 1, less than 1, less than 1, less than 1
Physical Tests
Water(% by FTIR)..less than 0.1, less than 0.1, less than 0.1, less than 1
Vi................14.3, 13.9, 13.5, 13.6
Soot %............0.4, 0.4, 0.4, 0.5
PQ Index.......38.0, less than 20, less than 20, 10
Fuel %.............1.0, 1.0, 1.0, 1.0
I'm a little worried about the jump in iron, although the PQ index is stable, and it is three times the distance of previous samples/OCI. The lead numbers appear to have stabilised. This is the first oil change after an AR-X clean and rinse. Redline 85 plus fuel treatment is used at a maintenance dose rate (2.5 ounces/tank) for pump lubrication and injector cleaning.
Any comments ?
Rick.
I intend to dump the oil, change filters and retest to establish a trend on D 1.
Oil Type
Analysis-Metals
Al...4, 5, 1, 5
Cu..1, 2, 2, 3
Fe..5, 7, 3, 20
Pb..4, 3, 8, 14
Contaminants
Si..2, 3, 3, 5
Physical Tests
Any comments ?
Rick.
