Blackstone comments:code:
Miles On Unit 184411 188572
Miles On Oil 4620 4161
Sample Date 3/13/2004 8/8/2004
Oil Type Pennzoil 20w-50 Rotella T 5w-40
Al 3 2
Cr 1 1
Fe 37 29
Cu 2 3
Pb 1 1
Sn 1 0
Mo 52 16
Ni 3 2
Mn 1 1
Ag 0 0
Ti 0 0
K 11 11
B 83 19
Si 5 4
Na 3 2
Ca 1966 3322
Mg 74 26
P 732 959
Zn 911 1185
Ba 1 1
SUS 210°F 79.1 78.8
Flashpoint 470 430
Fuel
Antifreeze 0.0 0.0
Water 0.0 0.0
Insolubles 0.5 0.4
TBN 5.2 N/A
Wear generally improved a little in the second sample from this engine. You dropped about 460 miles off your oil use and we think this is the main reason wear was lower. The oil's viscosity was high for a 5W/40 oil. If you are using an oil additive, this may be the cause, else it could be from the high soot levels we found. Soot often points to a combustion problem, but since upper-end wear (aluminum, chrome, and iron) was normal and no fuel was present, we really doubt it's anything to worry about. Try 5,000 miles on the next oil. We'll watch soot.
I did this mostly to see the difference between a CI-4 rated oil vs. SL oil. Yeah, the viscosity was different, seasonal temperatures change, etc... My concern with the soot is that it may be indicative of blow-by, possibly gunked rings? I'm currently running Auto-RX with Delvac 1300S out to 3,000 mi, rinse phase for 3,000 mi, then I'll probably perform another UOA to see if the Auto-RX cleaning made a difference.
