Here is an oil sample I took last January. I took this sample to check out the condition of the engine, and to see how a 15W40 oil performs in –40 weather.
6.2L Chev Diesel 2500
377500km, 4500km on oil, 1L oil added.
PetroCanada Duron 15W40
Sample Date Jan 28 2004
Factory Recommended OCI 4000/8000km
Staveley Services oil sample kit
New oil viscosity 100oC 15.6
New oil viscosity 40oC 117
Al 3
Si 6
Cu 2
Cr 0
Fe 30
Pb 8
Sn 0
Ag 0
Ni 0
Mo 2
Mn 0
V 0
Na 6
K 2
Zn 1771
B 44
Ba 3
Ca 2920
Mg 30
P 1772
% Wat 0
% Gly 0
% Fuel 0
Vis 40oC 118
Vis 100oC 15.2
% Soot 0.63%
I am happy with the results, the engine appears to be in good shape and the 15W40 worked fine, even if it was a little slow to build oil pressure at –40oC.
Carl
Al 3
Si 6
Cu 2
Cr 0
Fe 30
Pb 8
Sn 0
Ag 0
Ni 0
Mo 2
Mn 0
V 0
Na 6
K 2
Zn 1771
B 44
Ba 3
Ca 2920
Mg 30
P 1772
% Wat 0
% Gly 0
% Fuel 0
Vis 40oC 118
Vis 100oC 15.2
% Soot 0.63%
Carl
