I changed the OE fill at 6,000km and ran this oil until 14,000km. This truck is used mostly for work on weekends, hauling stuff in the bed. I do a mixture of hwy and a lot of stop/go/idling, about 800km per week. On a scale of 1-10 in terms of severity I'd say it's about a 7. I also drive in a lot of dusty areas which combined with a brand new engine explains the high silicon and iron.
As from other 6.0 PSD analysis I've seen before, the viscosity has taken a beating, from 15.4 to 9.8!
The fuel is also a little high at 3% but that number is also normal for new 6.0's and should be lower on the next analysis, unless I have problems with the injectors.
For this interval, I decided to try the Delvac 1300s 15w40. Do you guys think I should do an 5,000mile interval again or lower? Ford recomeends 5,000 miles for 'severe duty'. Any other comments welcome. First values are VOE
Glycol NEG
Water Soot 0%
Sulfation 56
Nitration 64
Oxidation 63
[ July 13, 2004, 11:47 AM: Message edited by: Quick_lude ]
- Aluminum 0, 1.3
Chromium 0, 1.1
Iron 1, 45
Copper 1, 10
Lead 0, 1.2
Tin 0, 1.3
Moly 2, 0.6
Nickel 0, 0
Manganese 0, 0
Silver 0, 0.4
Titanium 0, 0
Potassium 1, 12
Boron 0, 0.7
Silicon 2, 64
Sodium 1, 3.4
Calcium 3175, 2938
Magnesium 5, 9.0
Phosphorus 1083, 1005
Zinc 1241, 1192
Barium 0, 0.7
Viscosity 15.4, 9.8
Flashpoint 415,
TBN 12.5, 8.06
Glycol NEG
Water Soot 0%
Sulfation 56
Nitration 64
Oxidation 63
