I just got back my results from my first oil analysis. I have a 04 6.0 PSD. I'm hoping someone here can interpret it for me. Like the TBN number, and the visc100. This analysis was done by Oil Guard. Not as comprehensive as Blackstone however. I'll use Blackstone next time. I think it was interesting what they said about the viscosity being "Higher than typical for the given oil type" My oil was the factory fill with 3077 miles which someone here said was Motorcraft 10W30. Maybe it was really 15W40? Maybe my motor is not shearing the oil like some other 6.0's? Any input will be very appreciated. Thanks.
Sample ID: visc100 water SOOt fuel glycol
--------------13.6___0.1___0___0.2____0
Sample ID: FE CR PB CU SN AL SI NA MO K
-----------35_0__6__29__1__1_246_0__0__0
Sample ID: OXID NITR SYN SAE TBN
-----------0.6__3.7__0.0_43__8.3
Recommendations:
ENGINE WEAR RATES NORMAL FOR BREAK-IN/OVERHAUL PERIOD. ENGINE WEAR RATES NORMAL FOR FIRST OIL CHANGE. SILICON IS FROM ENGINE SEALANT (GASKET MATERIAL). VISCOSITY HIGHER THAN TYPICAL FOR THE GIVEN OIL TYPE.
Recommendations:
