Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
5 minutes 15 seconds ago
2007 corolla oil pan steel or aluminum?
by Rolla07
41 minutes 24 seconds ago
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
51 minutes 55 seconds ago
Paint correction
by mjoekingz28
53 minutes 12 seconds ago
Filtertran Filter From My Vehicle 96K Miles
by oil_abuser
55 minutes 48 seconds ago
Bleeding brakes cleanly
by mjoekingz28
57 minutes 43 seconds ago
Any thoughts on the Super Bumper? (Hitch Bumper)
by Fsharp
Today at 08:37 PM
Ransomware.....
by BrianF
Today at 08:22 PM
Electic motor lube oil
by Ztill
Today at 07:39 PM
CJ-4 Synthetic Oil for Kawasaki FX engine?
by lawnguy
Today at 06:54 PM
Body was there for months......
by OVERKILL
Today at 06:23 PM
Promotive by Purolator ph241/pl10241 13 months/10k
by Xrs2zz
Today at 06:01 PM
SkipKaye, MikeHancho, tempnexus, cobra1616z, meyer
56896 Registered Users
99 registered (901Memphis, 01_celica_gt, 2015_PSD, 04SE, 2009Edge, 5 invisible), 1447 Guests and 222 Spiders online.
56896 Members
66 Forums
244573 Topics
#586296 - 03/19/03 05:40 AM TDI factory oil at 2000 miles
Neil Womack Offline
Loc: Central Texas
Being obsessive I could not help my self. Sampled my factory fill 5w-40 on my new VW TDI at 2000 miles.
No make-up. No additives. Using Power Services in the fuel. Note: OEM oil unknown. Vehicle built in Brazil.
Iron 35
Chromium <1.0
Nickel <1.0
Aluminum 26
lead 1.0
copper 26
tin <1.0
silver <0.1
titanium <1.0
silicon 20
boron 4
sodium 6
potassium <10
moly <5
Phos 1075
Cal 3861
zinc 1151
barium 11
mag 16
antimony <10
vanadium <1
fuel % volume <1.0
T/S % volume 0.3
water <0.1
vis CS 100*C 10.0
lab notes: analysis indicates typical conditions for break-in. Drain oil and change filter.
lab: unknown contracted by John Deere Oilscan lab located in Stafford Texas.
Seems like the oil has sheared down a lot for 2000 miles.
#586297 - 03/19/03 08:25 AM Re: TDI factory oil at 2000 miles
TooSlick Offline
Loc: Dixie
Neil,
The factory fill is an SAE 0w-30, NOT a 5w-40 (note the viscosity of 10.0 Cst) ...most likely Castrol SLX. This is an ACEA B4 and VW 502/505 rated oil. Vw has been using a 0w-30 as the factory fill for about two years now.
TooSlick
#586298 - 03/19/03 01:32 PM Re: TDI factory oil at 2000 miles
Patman Offline
Loc: Oakville, Ontario
I hope it's not Castrol SLX (the oil I'm about to start using in our vehicles) since if it is, it's thinned out from 12.1 to 10.0 and has no moly. [Frown]
#586299 - 03/19/03 02:00 PM Re: TDI factory oil at 2000 miles
Neil Womack Offline
Loc: Central Texas
Patman
Guys on the tdiclub.com site show VW factory fill as a special break-in oil with a separate part number from the regular oil.
#586300 - 03/20/03 08:45 AM Re: TDI factory oil at 2000 miles
FowVay Offline
Loc: Southeastern USA
So, did you change the oil or just sample it?
I believe that this is the 3rd factory fill sample that we've seen that has been a Xw-30. I think there's a trend here,,, [Big Grin]
#586301 - 03/20/03 08:56 AM Re: TDI factory oil at 2000 miles
DABEAR95 Offline
Loc: Roseville, MI
quote:
Originally posted by Neil Womack:
Patman
Can you prove this? (I visit that site frequently by the way) I have never seen any proof from any source including VW that the factory oil is anything special.
Jason
[freaknout]
#586302 - 03/20/03 02:50 AM Re: TDI factory oil at 2000 miles
Neil Womack Offline
Loc: Central Texas
FowVay: I have not changed it yet. However this weekend the factory fill goes. It will give me a good chance to install my oil change valve. I have not decided if I'll run a 1500 mile run of Schaeffer's or someother oil. Any suggestions?
dabears95: I remember it from some thread on Fred's or maybe it was texastdi where someone cited a part number. Of course that does not make it true.
#586303 - 03/20/03 06:03 PM Re: TDI factory oil at 2000 miles
FowVay Offline
Neil, what do you intend to install this weekend?
I believe that the reference that you're making to the different factory fill is based on the VW factory fill spec of VW 521.73. The service fill for these engines is going to be VW 503 and 506 so apparently the factory fill is going to be the thinner oil, as evidenced by your and many other analysis reports.
#586304 - 03/21/03 06:51 AM Re: TDI factory oil at 2000 miles
Neil Womack Offline
Loc: Central Texas
FowVay The valve is a Fumoto (sp) valve. I bought it for my F-150 four years ago and ordered the wrong size. Turns out its perfect for the TDI.
edited to add
Almost forgot the manual I got with my TDI states that the factory fill was a quality 5w-40 oil. Unless they are careless while writing the manual or the TDI engine sheered the oil from a 40 to a 30 in 2000 miles.
[ March 21, 2003, 10:56 PM: Message edited by: Neil Womack ]
