Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
84 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 5 invisible), 1594 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
#586207 - 09/15/02 05:59 PM Amsoil 0w-30 in 1999 VW TDI
TooSlick Offline
Loc: Dixie
This is an analysis from VW's new turbocharged direct injection diesel, passenger car engine. This
vehicle used an oiled foam air filter and it also had a small, "Oilgard" by-pass filter. The addition
of the by-pass filter raised the sump capacity by 1/2 quart, from 4.7 qts to 5.2 qts. No oil was added
during this 10k run. Use is high speed (70-85 mph) highway driving for the most part - note the
number of total miles on this engine ....(The 0w-30 is not CH-4 rated, but does meet the VW 505 spec
for their diesel engines.)
miles on engine/111k
miles on oil/10k
Viscosity @ 100c/10.7 centistokes
oxidation < 1.0%
nitration/11.4%
TBN/12.8
Soot <1.0%
Fuel and water were fine
Fe/21
Cr/0
Pb/2
Cu/2
Sn/1
Al/9
Ni/2
Si/4
Additives
Boron/36
Mg/341
Ca/3144
P/1244
Zn/1541
TooSlick
#586208 - 09/15/02 06:14 PM Re: Amsoil 0w-30 in 1999 VW TDI
TooSlick Offline
Loc: Dixie
I should add ...most owners of these vehicles run either Delvac 1, 5w-40 or the Amsoil Series 3000, 5w-30. The Series 2000 and Series 3000 are very similiar basestocks with different additive chemistries.
TooSlick
#586209 - 09/15/02 06:28 PM Re: Amsoil 0w-30 in 1999 VW TDI
Patman Online   content
Loc: Oakville, Ontario
Fe is Iron right? Isn't this a tad high, or is this normal for this engine?
The silicon number looks awesome! So does the oxidation, nitration and TBN numbers!!
#586210 - 09/16/02 09:04 AM Re: Amsoil 0w-30 in 1999 VW TDI
Spector Offline
Loc: Chattanooga, TN
Has the iron level been coinsistent at this amount? This iron level is normal for me on a few cars but others seem to feel way too high. What is your interpretation of the iron level on this sample??????
Why the 0W in lieu of the 5W which is the diesel oil? Was it simply a test?
#586211 - 09/16/02 09:15 AM Re: Amsoil 0w-30 in 1999 VW TDI
dragboat Offline
Loc: Oklahoma
That oil is really built up is it not? I mean plenty of additives when I say built up. What would this do in terms of deposits over time?
Almost enough Zinc and Phophourus to race with!
So is this the new blend I have read about?
#586212 - 09/16/02 01:07 AM Re: Amsoil 0w-30 in 1999 VW TDI
msparks Offline
Loc: Clarksville, Tennessee
quote:
TooSlick
That looks great, I wish I would have gotten a sample of them TSO with 10K on it. Had to have the dealer change it as I was in the middle of a move and put Syntec [Eek!] in. Oh well, it looks like I will be running this stuff in my 03 TDI after I get it broken in. (Only have 800 miles so far)
#586213 - 09/18/02 10:27 PM Re: Amsoil 0w-30 in 1999 VW TDI
TooSlick Offline
Loc: Dixie
Spector,
Yes, I was just running a test ... I have lots of data with the Series 3000, 5w-30 in the TDI. These results were basically identical (Ox/Nit/TBN) to what I've seen with the diesel synthetic, in terms of oil degradation.
Dragboat,
This is the standard additive chemistry for the 0w-30/5w-30/10w-30, SL/CF formulations. There are some differences in the basestocks, however.
#586214 - 09/19/02 03:04 AM Re: Amsoil 0w-30 in 1999 VW TDI
MolaKule Offline
Loc: Iowegia - USA
For iron (Fe), the wear rate was about 2.1 ppm/1k, which pretty darned good, IMHO.
#586215 - 09/19/02 03:09 AM Re: Amsoil 0w-30 in 1999 VW TDI
TooSlick Offline
Loc: Dixie
Molecule,
With Delvac 1 or the Series 3000 (and no by-pass filter), this engine normally generates 20-40 ppm of iron every 10k. However, there is very little of anything else. Aluminum runs 8-12 ppm and there is almost no bearing wear. Copper/Lead/Tin are generally in the 1-3 ppm range @ 10k miles.
A very different wear pattern from the 2.0L, 4 cylinder VW gas engine....
#586216 - 09/19/02 08:16 AM Re: Amsoil 0w-30 in 1999 VW TDI
MolaKule Offline
Loc: Iowegia - USA
Yep, every engine has its own wear.
Each of my engines have a different wear rate. What I am attempting to do is a statistical analysis of wear so I can get a best fit wear equation for say turbos, nonturbos, 4, 6, 8 cylinders, gas vs. diesel, etc.
#586217 - 09/19/02 08:18 AM Re: Amsoil 0w-30 in 1999 VW TDI
MolaKule Offline
Loc: Iowegia - USA
Darn it, still cannot edit my own messages.
And oh yes, synths vs. dinos vs blends as well.
