Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
Cesna Citation Mustang - First impressions
by OVERKILL
05/28/16 05:35 PM
5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
93 registered (04SE, advocate, 2015_PSD, 29662, ag_ghost, abycat, 6 invisible), 1434 Guests and 328 Spiders online.
58001 Members
66 Forums
249539 Topics
Page 2 of 2 < 1 2
#586173 - 12/10/02 03:10 AM Re: VW Passat TDI Rotella T Synthetic
TooSlick Offline
Loc: Dixie
Al,
Not really an issue of viscosity, but rather thermal decomposition of the oil in the area of the upper piston ring. This engine is designed with a small "crevice volume" and the upper ring is in a very hot zone. Conventional oils tend to coke in the ring grooves and the rings stick. This is when you start to see elevated levels of both Cr and Fe in the analysis. You really want the PAO based synthetic in this particular application.
You can't fix this one simply by changing to a synthetic oil once it has started. You need to take the engine down and do it the right way. I have seen several cases where the Cr and Fe levels dropped a bit after synthetic was used for an extended period, so perhaps some of these deposits were loosened up, but it's a halfway measure.
#586174 - 12/10/02 03:39 AM Re: VW Passat TDI Rotella T Synthetic
Al Offline
Loc: Elizabethtown, Pa
Thanks [Smile]
#586175 - 12/10/02 05:10 AM Re: VW Passat TDI Rotella T Synthetic
Andy H Offline
Loc: San Antonio
Thanks for the words, TooSlick.
I don't know what the first owner used for oil. It was a VW lease, so I hope he at least used the Syntec from the stealership.
I used Mobil 1 and the Valvoline semi-synth for the first 4K changes after I bought it. Once I digested enough of the oil info on Fred's I switched to the AMSOIL.
I pulled the intake manifold right after I bought the car and cleaned it out. It was almost 60% blocked. The clogged intake had masked that the MAF had failed. I certainly wish I had this car from new...
I've got 6K on the current oil, I'll get some to the lab this week. And it looks like I'll be ordering a pan gasket...
Thanks Al and Sprintman for the Delvac 1 info. I can get the AMSOIL for less and I'm really looking forward to running the 5W-30.
(digging around...let's see..I got a 10mm socket here somewhere...) [Frown]
#586176 - 12/10/02 02:00 PM Re: VW Passat TDI Rotella T Synthetic
jjbula Offline
Loc: Montgomery, AL
quote:
Originally posted by TooSlick:
Al,
I'm not trying to push this stuff, I'm just thinking of buying a used TDI and am curious about your opinion. Would Auto-RX or another proven cleaner do the job without a teardown?
#586177 - 12/10/02 10:12 PM Re: VW Passat TDI Rotella T Synthetic
TooSlick Offline
Loc: Dixie
JJBULA,
I was just thinking that it would be worth it for Andy to try the AutoRX in this TDI engine. I'd run it in there with 4 quarts of a 15w-40 petroleum based diesel oil like Delvac 1300. Run it for 500 miles; change the filter, topoff the crankcase and run another 500 miles before doing a total change.
It's worth a shot for $25.00 and may reduce the problem to a managable level.
#586178 - 12/11/02 02:37 AM Re: VW Passat TDI Rotella T Synthetic
sprintman Offline
Loc: Canberra ACT Australia
TooSlick, my thoughts exactly. Gotta be worth doing IMO.
#586179 - 12/13/02 06:55 AM Re: VW Passat TDI Rotella T Synthetic
TexasTDI Offline
Loc: TYLER, TEXAS
quote:
Originally posted by sprintman:
Andy
You should give Delvac 1 a go in that engine. Most TDI owners use it now I hear. Several people here have found it for $10 gallon if I remember correctly, obviously mispriced.
Delvac-1 doesn't meet VW 505 specs, Amsoil does. [Big Grin]
#586180 - 12/13/02 06:59 AM Re: VW Passat TDI Rotella T Synthetic
TexasTDI Offline
Loc: TYLER, TEXAS
quote:
Originally posted by Andy H:
The current fill is AMSOIL 15W-40 Diesel/marine, which has 5600 miles in it. I'm looking forward to comparing the numbers.
I'm also using Amsoil 15w-40 in my 2000 Golf 1.9TDI and my 1991 Jetta 1.6 Diesel. [Big Grin]
quote:
The next fill will be Amsoil 5W-30....
Series 3000 I hope. [Wink]
I'll be switching to Series 3000 5w-30 at my TDI's next oil change as well. [Cool]
#586181 - 12/18/02 08:52 AM Re: VW Passat TDI Rotella T Synthetic
Andy H Offline
Loc: San Antonio
Hi All,
Chris, of course Series 3000! I got my bypass filter in the mail today as well. I'll do the oil and flushing and bypass change sometime this holiday break.
TooSlick and jjbula - What's AutoRX? Some type of flush? I thought of using a flush in the oil and maybe drizzling some in thru the intake valves and letting it soak down. Not sure how effective that would be. [I dont know]
I'm not sure if the rings would seat again if I pulled the bottom off and reinstalled the pistons...then all the "as long as I'm in here's" started calling...by the time I was done with my mental exercise, I had a fresh overhaul. [Roll Eyes]
I sent an oil sample to the lab last week and will take a look before the next step.
To be continued, me thinks...
Merry Christmas all,
Andy
#586182 - 12/18/02 09:31 AM Re: VW Passat TDI Rotella T Synthetic
Giles Offline
Loc: California
Consider Lube Control and Fuel Power for cleaning the engine.
Here's some links of interest:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=000106#000025
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=000112#000003
I ordered some and will be giving it a try.
Page 2 of 2 < 1 2
