talent doesn't pay like it used to.
by motor_oil_madman
02/07/16 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
02/07/16 06:58 PM
Valvoline white bottle 2.99 at Menard's.
by jhellwig
02/07/16 06:47 PM
EZ Car Lift Review
by JHZR2
02/07/16 06:32 PM
What oil for a beater vehicle?
by car51
02/07/16 06:01 PM
Buying services for new vehicles?
by powayroger
02/07/16 05:44 PM
Hard to find QSUD 0w20
by chiefsfan1
02/07/16 04:58 PM
Small compressor advice + a story of stupidity
by dishdude
02/07/16 04:33 PM
w116 300sd Lower shock bolt type/size
by Gito
02/07/16 04:20 PM
FRAM XG7317 Cut Open
by HX520W
02/07/16 04:17 PM
weld leaking on transmission pan.
by motor_oil_madman
02/07/16 03:41 PM
PP and Honda CR-V
by klt1986
02/07/16 03:04 PM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
102 registered (3800Series, 901Memphis, 04SE, 2002 Maxima SE, Abakev, AandPDan, 8 invisible), 1262 Guests and 221 Spiders online.
56846 Members
66 Forums
244385 Topics
#586149 - 12/23/02 01:47 AM 96 VW Passat TDI AMSOIL 15W-40
Andy H Offline
Loc: San Antonio
Hi Everyone,
Here's the latest (ok, second!) installment in the 'are my rings grinding themselves off?' saga which started here.
'96 VW Passat TDI 97520 miles
AMSOIL 15W-40 Diesel/Marine, 5743 miles on oil
Stock engine, Oilguard bypass filter, OEM full-flow, Purolator air filter
Changed bypass filter @ 97322 miles
Changed to AMSOIL 2-stage air @ 95900
Primarily two 18 mile trips per day, 60-80 mph
Used 2 quarts of oil (1 from Oilguard change)
LAB: Oilmaster Oil Analysis Dec, 2002
Just realized that I didn't change the Oilguard when I moved from Rotella T to AMSOIL... [Duh!]
code:
        Rotella  AMSOIL
Aluminum 9 3
Chrome 28 11
Copper 13 0
Iron 55 20
Lead 5 0
Tin 5 0
Silicon 17 0
Potassium 10 2
Sodium 3 1
Water <.1 .4
Oxidation 14.0 15.5
Visc@100C 14.0 14.2
Glycol 0 0
Fuel <2.0 <2.0
TBN 8.2 <3.0
SAE <5
Nitration <2.0
Soot 1.5 1.2
Ok..
Parts per mile (edit: hmmm..parts per million per mile?!)
Iron .0061 .0035
Chrome .0031 .0019
It looks like ring wear has dropped a bit. I've still got compression, so there must be some rings left. [Wink]
Anyone? Anyone? Bueller?
Andy
[ December 23, 2002, 08:13 PM: Message edited by: Andy H ]
#586150 - 12/23/02 01:48 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Andy H Offline
Loc: San Antonio
Oh, Yeah... The car gets new oil and filter for Christmas...
#586151 - 12/23/02 02:08 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Giles Offline
Loc: California
Looks like you found the oil to use! Nice to see before and after improvements like this.
#586152 - 12/23/02 04:07 AM Re: 96 VW Passat TDI AMSOIL 15W-40
satterfi Offline
Loc: CA
The silicon number sure looks better. I wonder it has anything to do with the lower wear metals?
#586153 - 12/23/02 04:17 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Andy H Offline
Loc: San Antonio
Ok... To add insult to injury...
I took the two samples differently. The first was mid-stream from the oil drain within about 5 minutes of shutting the engine down. The second was with the engine running, and was collected from the intake hose of the bypass filter.
For what it's worth...
Andy
#586154 - 12/23/02 04:39 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Al Offline
Loc: Elizabethtown, Pa
Yea better numbers. Maybe silicon as was partially responsible. But look at the TBN for Amsoil [Eek!]
[ December 23, 2002, 08:40 PM: Message edited by: Al ]
#586155 - 12/23/02 05:26 AM Re: 96 VW Passat TDI AMSOIL 15W-40
satterfi Offline
Loc: CA
Andy H
running a controlled test isn't easy.
new air filter, changing collection procedure, potential lab error (TBN is your case)...
You need a lot more than $25 per test to get it right.
But in any event, your engine looks to be OK without any major problems on the horizon. So be happy.
#586156 - 12/23/02 05:27 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Andy H Offline
Loc: San Antonio
Al, Yeah, this oil's dead. I'll do a flush and switch to the Series 3000 5W-30 tomorrow. I *think* the problem is that I left about a quart of Rotella in when I failed to change the bypass filter with the change to the AMSOIL. This is the first run with AMSOIL in this engine.
I was surprised to see water in the oil, tho - especially with the Oilguard.
I also used two cans of LubroMoly diesel purge for the fuel system this oil period. I don't have any idea if that could have shortened the life of the oil.
Andy
#586157 - 12/23/02 05:33 AM Re: 96 VW Passat TDI AMSOIL 15W-40
Andy H Offline
Loc: San Antonio
Hi Satterfi,
I didn't intend a controlled test, but now have two oil samples in a row and am learning each time. [Smile]
FWIW, these two tests were 'free' from Oilmaster - they came with the bypass filters.
I feel better about the engine, that's for sure. I really didn't want to tear into it for Christmas.
Speaking of which -- Merry Christmas All!
Andy
