Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
57 registered (AIRJAC3, 4WD, 2015_PSD, AZjeff, AirgunSavant, acbent, 6 invisible), 1077 Guests and 14 Spiders online.
58612 Members
66 Forums
252296 Topics
#586041 - 10/03/02 07:34 AM AMSOIL HDD 5W-30 in Dodge Ram diesel
Dick in Falls Church Offline
Loc: Falls Church VA
Oil Analyzers Inc
1994 Dodge Diesel 5.9L Cummins Turbo
Miles on unit 66094
Miles on oil 9000
Filter AMSOIL SDF 80 full flow
Filter not changed in the year
Makeup oil 2 qt
Fe 20
Cr 2
Pb 3
Cu 2
Sn 1
Al 9
Ni 0
Ag 0
Mn 1
Si 3
B 37
Na 4
Mg 31
Ca 4348
Ba 0
P 1201
Zn 1375
Soot <1.0
Oxd 4.4
Nox 10.0
TBN 12.0
Gly Neg
Water <0.05
Fuel<1.0
Vis 100C 11.0
oil suitable for continued use. Resample at next regular interval.
#586042 - 10/03/02 05:19 PM Re: AMSOIL HDD 5W-30 in Dodge Ram diesel
TooSlick Offline
Loc: Dixie
Dick,
Ever run the Amsoil 15w-40, HD diesel and marine oil in this same engine for comparison? Most of the data I've seen shows comparable wear rates between the two.
TooSlick
#586043 - 10/04/02 12:27 AM Re: AMSOIL HDD 5W-30 in Dodge Ram diesel
This truck was purchases pre-registered, and this was the first batch of AMSOIL run through it.
Friend runs fleet of Ford diesel commuter vans, about 100+ miles per day. He uses the 15W-40 in the older ones, 5W-30 in the newer. I believe that the quarterly oil samples showed better results with the 5w-30 in the newer engines, and also some fuel savings.
He just took one off the road with about 740K on it--engine and transmission fine, but body starting to fall off the frame, and the commuters weren't happy<g>.
